メインコンテンツにスキップ
2016年11月に発売されたAndroidスマートフォンのHuawei Mate9用修理ガイドとサポートです。
29回答 すべてを表示
Huawei Mate 9 PRO's screen is broken and looking for ways to replace
I am using Huawei Mate 9 PRO and the LCD screen was broken. Went to Huawei Customer Service Centre and realized that it was going to cost me RM841.60 which is relatively pricy. Here to ask for any ways to replace the LCD screen. Would it be cheaper to purchase the LCD screen through online? Which is the reliable website? Is LCD screen enough as I found some of the additional products needed such as touch screen digitizer and frame? Any answers are appreciated.
*Note : I attach the photo of my phone
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hello White Butler,
usually it is less expensive to replace the display on your own. Regarding to your question on the screen and touchscreen digitizer - it depends. What is exactly broken? In some cases the touchscreen and display both still work and only the front glass is broken. In this case it is enough to replace the front glass but you will need new adhesive for it and i can become complicated to repair and not to damage the display itself while doing so. There is danger to get bubbles between display and glass as well. But overall the front glass on its own is a lot cheaper than the display and or touchscreen of course.
If you want to go with the display or with the display with frame, it depends as well on what exactly is broken. If you want to replace the display without frame, usually you just need to take the battery out before you can replace the display. If you want to install a new display with frame, you need to transfer every component of the old phone to the new frame (motherboard, cameras, battery, charging board, loudspeaker etc.). This repair usually is a bit more expensive and more time consummating but depending on the phone sometimes easier.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hello Dominik, which type of glue I can use to fix the glass ?
I read the manual, but i have this doubt.
For example the Ipad glass has already the adesive, the Huawei one no.
Thank you
さんによる
Hi Giandonato,
since the Mate 9 Pro isn't waterproof you don't need special adhesive for this. The best way to secure a new screen is with a sheet of custom-cut double-sided tape. You can order pre-cut adhesive strips or try to cut them by yourself. After installing the screen, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
さんによる
コメントを追加
Same problem and no one can fix too expensive 850 pls any one knows any one can fix the outer screen
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
White Butler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 2,122
