Crank but don't start
I have a 2004 Pontiac Grand AM that cranks but does not start. We have replaced the fuel filter, fuel pump, fuel regulator, and fuel pump switch but it still does not start. Can you send me any more advise????????
Get your car scanned for codes first off. Always do that before replacing anything.
I'd bet though it is probably your crank angle sensor, but get it scanned first.
このアンサーは役に立ちましたか?
u must check engines before start ur car thats very imporant ur car before on road grab some sensor battery and check on battery on your car maybe is low or high and also dont forget about the oli its may low oil if oil is empty the car won’t started
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 26
過去 30 日: 154
今までの合計 3,496
Please help ???????
Jimmy Samora さんによる
After everything I had told you I was going to replace the crankshaft angle sensor and disconnected the negative on the battery after some delays I connected the battery back up and just out of curiosity tried to start the car and of all things the car started. Can you give me a opinion on why the car started.
Jimmy Samora さんによる
That worked for me! Just disconnected the negative on the battery for a little while and reconnected it. Thanks! 2005 Grand Am
Whitey Stange さんによる
