メインコンテンツにスキップ
ゲームボーイは1989年4月21日に、まず日本で発売されました。その後、1989年7月31日に北米、1990年9月28日にヨーロッパで発売されました。大型のグレーのケースが特長で、モデル番号はDMG -01です。
I'm having issues with the unit reading games. (Details inside)
I recently bought a non-working unit from ebay for cheap. I saw that the battery terminals were corroded and that they were in desperate need of a cleaning. I also noted that there was a small, albeit significant, amount of corrosion on the board. Foolishly, I chose to disregard it, as the issue with the terminals was solved and the unit was able to power on and display the startup logo. It seemed like it was in 'working condition' at that point, but it refused to register/ play games when I tested it later. The furthest I got was the Nintendo logo with Tetris, and when I tested Pokemon Blue, the unit went berserk! There were wavy lines all over the screen! The unit also made a buzzing sound, which totally freaked me out. Whether or not the non-working speakers emitted it I am not certain, but it was enough to completely scare me away from ever giving power to the board again. Cleaning the cartridge didn't yield any results, so I investigated further. I disassembled the unit once more and found that the corrosion had traveled inside of the game port. Crap! So much for my cheap project! Does anyone have any advice on how to fix this? I'd also appreciate if anyone could provide an explanation on the mysterious lines and buzzing noise, as they were very unnerving. I'll provide pictures if need be.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
@beanking those lines etc. can all be caused by corrosion on the port as well as the rest of your boards. You do want to clean all of them and see what you get. Attached are the schematics for the GB that I have available GAMEBOY.pdf that you can use for further troubleshooting.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
@oldturkey03 How would I remove the corrosion on the port? Also, do you know what would cause the frightening buzzing noise?
さんによる
@beanking some baking soda, a toothbrush, and warm water to remove most of this. After that use 95%+ isopropyl alcohol to clean the board and all the other parts extensively. You need to do that a couple of times to remove the water and baking soda residue.
さんによる
コメントを追加
回答を追加する
Mr. Bean さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 730
