メインコンテンツにスキップ
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
79回答 すべてを表示
cranks over just doesn't start
Lost power while driving down the road. Have all lights and cranks over just doesn't start
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
Won't start hot, if you leave it sit overnight to get cold again will it start? If it does it is a crank angle sensor. Also what year and model is it. What engine size 4 or 6. Auto or manual. What was happened while driving? Were there any other symptoms of hard starting before this happened.
さんによる
It is a 91 Camry 4cyl auto. I was driving and it just died. No sputtering and dash lights still on. I pulled over and tried to start it but it only cranked over no start. New battery, alt, and starter fusible link is new also. Tried to start again today almost as if fuel isnt getting to carb but has 3/4 tank
さんによる
So I just found a vacuum line that broke off the part but do not know what the part is or if this is the problem. How do i find this out? It has 2 lines on it and sits near the distributor
さんによる
@mothelona post some pictures of what you are looking at with your question. Use this guide iFixitでの質問に画像を追加する方法 for that. It will let us see what you see.
さんによる
I'm having the same problem the pump is good just won't turn on when I crank the car I replaced the relay its working but still nothing and the fuses are good to
さんによる
コメントを追加
1 件の回答
ベストアンサー
Do you have sparks on the plugs when your crank the engine? Use a spare plug and check on a video something like this https://www.youtube.com/watch?v=mUOmsGii... at 1:50 and see if that gets a spark. Of course you can also purchase a spark tester and do the same thing. Could be a spark issue as well as a no fuel to the injectors (no carb) due to fuel pump etc. Check your fuses to make sure the fuel pump gets power. Your Camry should have a fuel pump relay (EFI main relay see image)
and fuse in the fuse box under the hood. Check there first
Here is the Fuel delivery part of the manual Toyota-EFI.pdf . Start with the section on page 12 and let us know if you need more help with that.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks i will check the fuel
さんによる
コメントを追加
回答を追加する
ALANA さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 38
今までの合計 6,555
