Where is the starter in the 2004 stream located
Car is tumbling but not starting need to locate the starter
@andrewtheguy123 there are two engines listed. A D17 and a K20. D17 the starter is under the intake manifold and K20 under the resonator. Lets see if this will help you.
Here is the wiring diagram
Here is the how to file://L:\A00\HTML\11\S7A1E11A46500056901KBAT00.HTMLfile://L:\A00\HTML\10\S7A1E10A46500056901KBAT00.HTML
このアンサーは役に立ちましたか?
If it is a front wheel drive transverse engine/east-west engine according to the number one cylinder which is usually to the right side of the engine.
Then the starter will be at the back of the engine near the firewall. Connected to the transmission or manual gearbox.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 11
過去 30 日: 45
今までの合計 3,234
