メインコンテンツにスキップ
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
212回答 すべてを表示
Maytag washer run problem
I have a Maytag washer that with run fine and fill up but once it fills up it will stop. To get it going again I have to hit the front top right corner of the machine with my hand. Once I do that it starts back up and runs through the cycles perfectly. Any ideas what I should look for? Thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Do you feel like the Fonz when it goes back on again? :)
If it's full of water and not spinning then it's most likely your lid switch is broke/or breaking.
When you're hitting it you're probably knocking it temporarily on and then the machine shakes and it goes off.
Try this:
https://www.youtube.com/watch?v=pghabRPu...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
John DiPerrio さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 258
