メインコンテンツにスキップ
モデル番号はA1059もしくはA1099/20、40、60GBハードドライブ/タッチ反応クリックホイール
227回答 すべてを表示
Showing less than 20GB storage
I've restored my 20GB 4th Gen (A1059 model) ipod although the memory on the ipod and on windows XP is now reported as being 3.55GB!
Have tried to reformat, HDD scan in diagnostic mode, etc. and all tests say okay. Still 3.5gb though...
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
2件の回答
I have had a similar issue because of bad sectors on my drive. You may have to replace your HDD. You will not have to reformat the drive when you do a restore through iTunes. That actually prepares the drive for use in your iPod it "formats" and transfers the firmware to your drive.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Okay thanks, looks like I'll have to reconsider a new drive - probably pick one up quite cheaply.
Again, thank you.
Carl
さんによる
You are welcome and the drives are relatively inexpensive on eBay. Good Luck
さんによる
コメントを追加
Hello!
Answer's a bit late... over 2 years, but I thought it may be useful to others having similar issues.
I mainly work with these iPods and over time I noticed this problem was recurring over a large amount of hard drives. So I decided to purchase a 1.8" IDE to USB adapter. They allow you to connect the hard drive directly to your computer without the use of the iPod.
Doing so showed that the hard drive needed formatting as it was damaged. I formatted and then again it displayed the same hard drive size around 3-5GB.
I then tried a more drastic restore, go to control panel, then administrative tools, then computer management, on the left you will see a drop list of options, go to storage then disk management. Here my hard drive was displayed as it's real value of around 18-19GB but 14-16GB of it was unallocated.
You can allocate it using windows but I already had a program that manages your Hard drive called Mini Tool Partition Wizard so I loaded that up and there it was again, the same unallocated space. I deleted the 3-5GB that was allocated making it 17-19GB unallocated. Then you allocate it. Go back into my computer and you should now see the hard drive with it's real value, Quick format it to set it back to the allocated letter windows prefers. Insert it back into your iPod and connect it to your computer to restore using iTunes.
You'd be surprised how many iPod hard drives I get just needing this simple fix.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 697
