メインコンテンツにスキップ
The Protocol Vento, released in 2017, can be identified by its model number: 6182-7RC. This model is Wi-Fi capable and includes a digital camera for capturing photos and streaming video.
5回答 すべてを表示
Why won't my propellers spin when I try to take off?
When I turn on my drone and connect the controller the lights go from flashing to solid but then the drone won't take off. The propellers spin for a second but then nothing happens. Help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
There may be hair or debris entangled in the base of your propeller. To remove the debris, use the little silver lever (that comes with the drone kit) to pop off the propeller. Clean out the base (you may need some tweezers), and then just pop the propeller back into place. If that doesn't work, or if you know there isn't any debris, you may need to replace the propeller altogether. Here's the link for the manufacturer's replacement parts: http://www.protocolny.com/spareparts/dro...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Maria Larcomb さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 373
