メインコンテンツにスキップ
2016年3月に発売された4インチのiPhone。ハードウェア仕様は6sに類似しています。シルバー、スペースグレイ、ゴールド、ローズゴールドのカラーが揃っています。16/64 GB容量、Model A1662とA1723
1049回答 すべてを表示
iPhone SE won't display after lightning connector replacement.
So I was wondering if I could get some advice. I opened up and replaced the lightning connector on the iPhone, but after testing it the headphone jack wasn't working. So I decided to open the iPhone again to see if there was a problem with which I installed the connector I found none. The problem is now the screen won't turn on and I have no idea if the connector got messed up or the screen is broken. I connected the iPhone to my laptop and iTunes detects the iPhone and even it's name, but I haven't been able to get any other response. I am stumped as to what the problem could be has anyone else had a similar issue?
P.S. I noticed that the cable battery cable seems to have some 'styrofoam' looking part in it and I don't know if it's relevant.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hey have you tested a hard reset?
Hold power button and home button the same time up to a minute, relese when you see the apple logo.
If that dosent work, I would open it up, relse the plate over the connectors for the battery and lightning and look if anything looks damaged on the board
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eli さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 32
