メインコンテンツにスキップ
2015年3月に発表され、同年4月10日に発売されました。Galaxy S6 Edgeは Samsungの最新のスマートフォンで曲面ディスプレイをもつデバイスです。
237回答 すべてを表示
Can I switch motherboard memory capacity?
My S6 Edge has a faulty motherboard and Samsung had a look and its beyond economical repair and past its warranty.
I want to buy another board and get a local repair shop do replace it. But I'm struggling to find another 128gb board, would I be able to replace with either a 64gb or 32gb? Looking on ebay I can get a 64gb for less than £100, so hoping I can just put another one in and im good to go!
Any advice would be appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Hi!
You can change the board with a lower-capacity model, just make sure the local repair shop will accept the job. Also, you need to be absolutely certain that all your stuff will fit on the smaller memory board.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
It is also very important that you match the precise model number of your board. Since you posted prices in Pounds, I will assume your phone is likely British stock, a G925F. Do not replace your board with a G925c/t/a/v/p/0 as they will not be compatible with your g925f charger port flex cable.
Were you to order a g925t/a/c motherboard, you would also have to order a matching g925t flex.
A G925v/p/0 motherboard also may not fit (sit flat) on your existing frame.
Any model number other than G925f will support different 3G and 4G LTE bands, so you may lose support for your carrier.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Dan Copeland さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,028
