メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
196回答 すべてを表示
My touch bar got cracked and is no longer functional
My touch bar got cracked and the display is no longer functional, can someone give me an estimate how much would it cost to get the touch bar display replaced form the  store?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
have you got a image, how did it become cracked ?
さんによる
コメントを追加
2件の回答
最も参考になった回答
Replacing the touch bar requires a full topcase replacement, and Apple will replace the battery with it. Unfortunately it's pretty expensive. A full topcase assembly comes in (prices from the netherlands) at roughly 500 euros (€ 499,20 to be exact, excluding taxes, which brings it up to 600 euros in the netherlands). Add labour to that to get a full estimate, and you'll end up in the 700 euro range.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I would imagine it would be pretty expensive it would most likely be a top case replacement, and not only that I don't if apple will also change the logic board as they are married to the touch i.D sensor which is part of the touch bar.
このアンサーは役に立ちましたか?
スコア 0
コメント:
Sorry, this is not true. The touch id sensor is a seperate part. It is possible to only replace the touchbar, but this is not for the faint of heart. A new touchbar comes at prices around $50, but to replace it is a nightmare.
さんによる
Sorry, yes i know that, but I was explaining the outcome if he visited an apple store because that is what he asked for.
さんによる
コメントを追加
回答を追加する
Saad Ahmad さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 16
今までの合計 1,845
