メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
Help me plz. iPhone 6 Plus keep showing temperature warning
Hye ! I have an IPhone 6 plus sent in to me from other shop. When I look around the board, all the VCC_Main cap are removed, the reason this IPhone sent to me is because it keep showing temperature warning even not in hot condition. Before this the IPhone is a water damaged and it already power on, but the only problem is the temperature warning issue.
What should I do now ??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
Temperature error messages are usually related to either defective NTC's (negative thermal coefficient thermistors, such as R1308 etc.) or true excess heat caused by another issue on the logic board. The VCC caps have nothing to do with it. Clearly the previous tech was searching for a shorted component on VCC_MAIN.
Because this phone was water damaged, it must be properly decontaminated first. If that hasn't been done, that should be your first priority. After that, check the thermistors and if those look good, you have to start probing all of the main, PMIC and PMU_RF voltages to get a sense of what is wrong with the phone.
このアンサーは役に立ちましたか?
スコア 4
3 件のコメント:
The thermistors looks good, none of them shorted to ground either. When I put the board on my face there is no heat detected. Would you give me a guideline for probing the PMIC ? Where should I start first ?
さんによる
Start with VCC_MAIN, BATT_VCC & PP5V0_USB. For the PMIC, check the voltage rails it generates:
* The PMIC generates ~15 voltage rails. They are all important (for obvious reasons) but the ones to check first are as follows: PP_CPU, PP_GPU, PP1V8_SDRAM, PP1V2_SDRAM, PP_VAR_SOC, PP0V95_FIXED_SOC, PP3V0_Tristar, PP3V0_NAND, PP1V8_ALWAYS and PP1V0.
* The PMIC also generates, what I would consider secondary, yet still important voltage rails for the following sub-systems: PP3V0_MESA, PP1V8_VA_L19_L67, PP3V0_PROX_ALS, PP3V0_PROX_IRLED, PP3V0_IMU, PP3V3_USB and PP3V3_ACC
さんによる
okay i'll try check the rails. Thnx for the guide line sir. (Y)
さんによる
コメントを追加
Hi,according to your description,the NTC thermistor may be broken due to the water damaged before.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
ive checked the thermistor, there is no short sign and also the resistor showing normal value
さんによる
コメントを追加
iphone 6s temprature error
i change battery
i check the chips also
but it is not heating much
but still showing temprature error
tell me what should i do
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Azim WHITE さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 15
今までの合計 2,094
