メインコンテンツにスキップ
The Brother MFC-440CN is an all-in-one color inkjet printer with a photo bypass tray first introduced in 2001.
9回答 すべてを表示
Clear "paper jam" message
On a MFC-4420DW I'm attempting to print business cards on Avery stock through the rear, single sheet feed tray. Data transfer from PC is very slow, and when printing begins only the first quarter of image prints and sheet exits printer. Thereafter I get a Paper Jam message. I have followed the "clear paper jam" instructions several times, referred to online instructions, used a letter-sized sheet of glossy photo paper for the "remove paper scraps" function, but printer does not grab the sheet. I have closely searched the inside of the printer for scraps and can't find a thing. How can I clear the error message so I can use my printer again?! Frustrated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Have you set the printer preference Media Type in the computer, to 'other photo paper' to allow for the thicker paper that you are using? You didn't say.
if this doesn't work in the Paper Size preference you can specify the 'thickness' of the paper that you are using.
What OS is installed in the computer connected to the printer?
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
katiepricega さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 10
今までの合計 546
