メインコンテンツにスキップ
Kindle 3はAmazonによって発売された第3世代のKindle製品です。Wi-Fiもしくは内部ストレージが4 GBの3Gコンフィギュレーションです。
76回答 すべてを表示
It only gives me the yellow light. No life other than that what's wron
The Kindle is plugged in and only the yellow/orange light comes on. I have books I would like to download, but I don't know what I need to fix this problem. There is no life in the Kindle 3 but the charge light.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Try to slide and hold the power button for half a minute or so, then release it - This should restart your Kindle. This is the official solution from the manual I believe.
If it does not work, look at some of the other solutions posted in Screen not responsive, what do I do? There are several (one of them by me) - and one of them should do the trick.
For saving your books, did you try plugging in your usb into a computer? It should recognise your Kindle as external drive, then you can go into the documents folder and just copy your books.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Pat Kingsmill さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 11
今までの合計 124
