メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3531回答 すべてを表示
Not Charging after replacing battery
I was trying to replace the swollen battery in my daughter's iPhone 5s with a recently purchased and functioning iPhone 5c battery. I have replaced batteries and screens on the iPhone 5c devices several times, so I am familiar with the care needed to not damage ribbon cables and connectors during the swap. After replacing the battery though, her iPhone will not charge. I removed the battery and put it back into the iPhone 5c and it charged just fine. Also, when the battery is charged, I was able to sync the iPhone 5s to iTunes and saved a back up of her files, photos and music. I checked all of the connections several times, including the small single wire that plugs in near the battery plug and the plug from the charging port. I do not have a USB Ampmeter to properly test it as I am a DIY type. Any thoughts on what to look for?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Either the charging port is busted or the Tristar chip needs replacement which requires micro-soldering work done on the phone. You can find reputable repair shops that offer a no-fix no-fee model to get them to fix it for you.
You can quickly test tristar by unplugging the battery then plugging the charger in and see if it shows apple logo or not, if it does not then the tristar chip is not. Usually I would test another charger port if possible to rule that out.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
So, without the battery installed, if I plug the iPhone into the lightning cable and charger to power, I should still get the Apple logo? I tried it, I put the screen back on but did not reconnect the home button and plugged it into charge, I did not get the Apple logo, that means the chip is busted. Is that correct?
さんによる
Yes if you can't get Apple logo to appear when screen is connected and battery unplugged Tristar chip needs replacement.
さんによる
コメントを追加
The 5C battery is not the exact same as the 5S battery even though it does fit. Try ordering a 5S battery and see if that fixes the issue.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
They both work vice versa On 5s and 5c, that's not the issue.
さんによる
コメントを追加
回答を追加する
Donny Sanders さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 1,793
