iPhone 6 plus no backlight
Hi, how to troubleshooting backlight iPhone 6 plus
Im newbie in micro soldring
この質問は役に立ちましたか?
この質問は役に立ちましたか?
For a backlight problem, you will need to check the backlight circuit (U1502) on the logic board (have you already tried another screen first?). The usual failure point is with the backlight filters (Fl2024/FL2025/FL2026) so that is what you must check first. If the filters are okay, then work your way back to the backlight diode (D1501), the backlight coil (L1503) and the backlight driver itself (U1502).
You will need to find and download the schematic for the iPhone 6 if you haven't already done so.
このアンサーは役に立ちましたか?
For micro soldering you must have a microscope. About backlight, you need view mother board in detail under microscope, in 80% you can find suspicious SMD components on board, and fix your Phone.
このアンサーは役に立ちましたか?
I already have microscope
first began to check j2019 2/4/6/8/10 in diod mode the red in GND the black on the pin no value
check filter FL2024 Fl2026 Fl2025 and Fl2044 Fl2045 Fl2046
to check filter you need to put your path in each pin no beep filter is dead change it after that no way change u1501. good luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 195
1件のコメント
@refectio could help
Aiden さんによる
