Front wheel bearing relpacement
How does one go about removing and replacing the front wheel bearings on the 2008 Kia Optima?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Unfortunately, I looked up your vehicle and it appears that you have pressed bearings, meaning you can’t undo couple bolts and put a new one, you have to have a press and a couple other tools. Your best bet is to take it to a shop, it’ll pay off just not having to do it yourself it’s a pain. Unless you like working on cars then look up “how to replace pressed-in bearings” Goodluck!
このアンサーは役に立ちましたか?
just look for your bearing on Ebay but make sure you order the correct OEM number. You can get this by googling OEM and the part name.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 954
