メインコンテンツにスキップ
2.3GHz, 2.6GHz, or 2.7GHzクアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大3.7GHz) 6MB 共有L3 キャッシュ付き。
561回答 すべてを表示
No screen power after removal LCD cable without powering laptop off
Hey there guys,
I recently noticed my hinge was loose, so I opened up my macbook pro, and disconnected the LCD cable, but I was stupid enough to not unplug the battery cable, so the device turned on and the fans ramped up to full speed.
After reassembly, the device wouldn't turn on at all, no chime....
After resetting the SMC and PRAM I hear a chime, and the keyboard LEDS light up, but the screen stays black.
I can also press keys to hear my PING sound for errors, the laptop is fully functional I guess?
Shining with a torch trough the apple logo resulted in even more blackness. (I Didn't see anthing)
When I connected the laptop with an MiniDP cable to my 27" 2009 iMac, it recognized it, but a black screen. That could also be courtesy of the cable.
I've tried reconnecting the LCD cable at both ends, but no luck.
Could someone help me, it would be very appreciated.
Thank you,
Tristan
EDIT:
Fuse image:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
You probably blew the backlight filter and fuse.. Common issue when you forget to disconnect power. It will need board repair.
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
So there's practically nothing I can do about it? That's a bummer. A board repair will probably cost 200-300 Euro's, which I don't have at the moment...
Is there any way I can check this? Physical damage to a part?
さんによる
If you have a microscope, you can pull the board and look for any burnt components near the LVDS cable and near the backlight driver but not much you can do without microsoldering equipment.
さんによる
I just tried looking at the board with a 8x zoom on my phone, and everything looks fine around the connector, so I hope it could be something else.
さんによる
It's probably going to be the fuse on the other side of the board
さんによる
I will remove the board tomorrow and I'll look, thanks for the help so far. Even if it is negative. There aren't many ASP's here in the Netherlands, and the closest is a 2,5 hour drive.
さんによる
4件以上のコメントを表示
コメントを追加
回答を追加する
Tristan van Triest さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 233
