Why will my coffee maker only brew about 2 ounces of coffee?
About 4-6 months after buying the K70 Keurig, the coffee maker will only brew about 2 ounces of coffee, even using the largest cup option. The coffee maker has been cleaned several times & nothing seems to help. I just quit using it for a long time, but I got it out again recently & tried it. No luck! What are my options. It was kind of expensive to just throw it away after using if for such a short time.
3 件のコメント
Do the 2 ounces come out hot? And do the level of brewed coffee vary every time you brew?
Ricardo Martinez さんによる
Also, are you using the right size k-cups for this model?
I am having a similar problem with a brand new K-slim. This has occurred straight out of the box. This is an intermittent problem, mostly on the first brew of the day. I reset the k cup and then it works. I have gone through all the cleaning methods with no results. It seems there is something wrong with the CPU of the unit. My water supply has a whole house filter system and I noticed that Keurig says to not use distilled water. My water filter system is not an RO unit so I would say it is not distilled. There are no signs of scaling with this new unit. Anyone else having the same issue?
John B さんによる
