メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
iPhoneの第4代目で、修理はそのままパーツを直接交換するだけです。しかし、正面ガラスとLCDはセットで交換する必要があります。容量はGSM / 8,、16m32 GB / モデル番号 A1332 /本体カラーは黒と白色
3306回答 すべてを表示
iPhone 4 clock losing time
I was asked today about an iPhone 4 (A1332) which seems to have a problem with the real time clock. Now and then it loses maybe half an hour and then recovers the correct time a day or two later. Text messages don't seem to come through when it's in that state.
I suspect it could be a problem with the RTC chip (probably not a separate chip but a function integrated into the processor or one of the peripherals) in which case it's probably not fixable.
Probably the only chance of a fix would be if it's a software problem, so I suggested backing up her data and doing a factory reset. But if the flash memory is getting tired a complete reflash of the kernel would be more likely to do the trick. Not sure how to do that. Ideas? Or other suggestions?
Regards - Philip
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
@pleriche this "Text messages don't seem to come through when it's in that state" sounds more like a connection issue. Check the antenna cables etc. If not check with a new Sim Card and see if that will help.
さんによる
コメントを追加
1 件の回答
選択されたソリューション
Real time clock is a waste of time to diagnose on a old phone. Better yet to get another 2nd hand iPhone 4 rather than try to fix the problem as it would be a lot cheaper and less time spent.
You could try restoring the phone via iTunes but you would need to do a backup first. I doubt it'll help though.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Philip Le Riche さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 138
