メインコンテンツにスキップ
2.0GHz, 2.3GHzもしくは2.6GHzクアッドコアIntel Core i7プロセッサ (Turbo Boost 最大3.8GHz) 6MB共有L3 キャッシュ付き。
580回答 すべてを表示
Can I replace the trackpad on a Late 2013 15" MacBook Pro Retina?
My trackpad will work for about a minute or so after startup and then stops completely. Is it possible to replace this part? I don't see any parts or instructions on iFixit. Many thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
2件の回答
最も参考になった回答
While the Both the 13" & 15" models use the same procedure MacBook Pro 13インチ Retina Display Late 2013 トラックパッドの交換 to gain access to the trackpad (technically a touchpad). The 13” model uses a different part MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad which won’t work in your 15” model.
You need this part: MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpad.
@ajcooke01 - Replacing the full uppercase is not really needed here.
MacBook Pro 15" Retina (Late 2013-Mid 2014) Trackpadの画像
製品
$69.99
MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpadの画像
製品
$49.99
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
I have found that just replacing the cable works fine. There is very little that can fail on the trackpad. MacBook Pro 13" Retina (Late 2013-Mid 2014) Trackpad Cable
さんによる
@mayer - Very true!
さんによる
Please help. Macbook pro late 2013 edition trackpad = non responsive, keyboard response is delayed or non responsive. Can one replace just these 2 parts? Which other models are compatible if so. Where can I find replacement parts?
さんによる
@margot23 - iFixit sells the trackpad, click on the correct part above 13" or 15" depending on your exact model.
さんによる
コメントを追加
I bought a new upper case for my late-2013 15" MBP. It included the keyboard but not the trackpad. I'm hoping these instructions for the 13" MBP will be all I need to transplant the trackpad to my new(er) upper case. I have a new battery to install too.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
@reezekeys - Why are you replacing the uppercase?
さんによる
I had a few keys of my keyboard stop working. I went to Ebay to get another one but found an entire upper case with keyboard in excellent condition for $9! It had no trackpad though. I also needed a battery so I got one, and figured I’d do both jobs in one shot.
さんによる
@reezekeys - I would also replace the battery as well. Just follow the guide to transfer the trackpad.
さんによる
I needed the battery for a long time, you know how that goes! Then the tab and function keys on my keyboard stopped working.
さんによる
コメントを追加
回答を追加する
gslive さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 7,623
