メインコンテンツにスキップ
The HP Flyer Red is a laptop created by Hewlett Packard which was released around December 2014.
31回答 すべてを表示
My computer suddenly turned off and won't turn back on..
I recently bought the HP Flyer Red laptop and it has been working great for about a month until I cut the camera on and it suddenly turned off 2 days ago and won't turn back on. I tried charging it and taking the battery pack off. It came on for a split second and turned back off. I tried it again today while charging it and it came on but went to a dark gray screen with just the mouse pointer showing. What could be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
What do you mean by "cut the camera on"?
What OS is installed in the laptop?
Have you tried starting the laptop with the battery removed and only the charger connected?
If it starts OK allow it to boot all the way to the Windows desktop, let the HDD activity settle down a bit and then shutdown the laptop in the normal manner.
When it has completely shutdown, switch off the charger and disconnect it from the laptop
Reinsert the battery, reconnect and switch on the charger and then turn on the laptop.
If it starts OK allow it to boot all the way to the Windows desktop.
Check the battery charging status and if the battery is charging allow it to fully charge before switching off the charger and disconnecting it from the laptop.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
My camera turned on and now won't turn off
さんによる
Hi @Shania Bacchu,
Not quite sure what you mean.
Are you asking about the webcam in your HP Flyer Red PC?
If so what is the exact problem?
What program are you using the camera with etc?
さんによる
コメントを追加
回答を追加する
krcayson1982 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,390
