メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2686回答 すべてを表示
Phone won't charge on 5W charger
My phone suffered some light water damage and works completely fine. The only issue is that it does not charge on the typical 5W charger. It did work on a 12W charger earlier, however. Why would this be? Is there some easy repair or replacement I can do to fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The iPhone is capable of charging up to 1.67A on a standard 5V wall charger, so if you have an iPad charger (12W) you can use that.
The issue with the charging is due to the liquid damage probably near the charging port connector or a corroded charging port assembly.
Worst case scenario is that there is liquid damage on the board and it's fairly common for the charging ic (tristar) chip on the logic board needing replacement after liquid damage.
If that does need to be replaced it can only be done by someone that does micro-soldering / board level repairs on iPhones.
There could be more liquid under the metal shields on the logic board and may be slowly damaging the phone over time. You may want to open up the phone and see if the phone is still wet, has signs of corrosion (white marks) on the connectors of the logic board.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Ray Engle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 323
