メインコンテンツにスキップ
2014年9月19日に発売されたこのiPhoneは4.7インチのスクリーンサイズでiPhone 6 Plusの縮小版です。
4730の回答 すべて表示
Phone suddenly turning off after battery replacement
Yesterday i had my battery replaced because the old one was bad.
I came home and put it on charger to charge it fully since it was dead.
After several hours it was 100% so i unplugged it. I was just reading something online when it suddenly shut down. I tried starting it and nothing showed. After plugging it back it showed that the battery was drained and it started and showed about 11% battery. I charged it to about 75% unplugged it and started messing around in settings when it went off again. After few of theese i noticed that the battery dies when it should lose 1%. For example it was 75% and rather than going down to 74% it lost all of its battery.
I had the battery changed at service and not at apple store because there isnt any near to me.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
1回答
It sounds like you have a defective battery. Or at the very least, a used battery that has damaged cells. Take it back to the service and report the problem, they should replace it at no charge. Defects happen, so unless this is a common occurrence with the service you used, it may be totally random that this happened.
この回答は役に立ちましたか?
スコア 0
コメント:
Ok thanks.
I will go there and report it and hopefully they will help me.
による
コメントを追加
回答を追加する
Niko Albert さん、ありがとうございました!
統計データを表示:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 36
今までの合計 904
