メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Garmin Nuvi 56LMTは、5インチのデュアルオリエンテーションディスプレイを搭載し、北米の地図をプリロード済みのポータブルナビゲーションデバイス(GPS)です。音声案内や無料の無期限渋滞回避機能を備えています。
Why won't my GPS run?
I just bought this gps from a place on ebay. I started out for Florida got down the road a ways and stopped and put address in it , It ran for about 30 seconds and quit and won't come back on.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
These units are not meant to run on battery.
They need to be constantly plugged into a cigarette lighter via provided adapter.
You can test if this is at fault by simply connecting a USB-A to mini (not Micro) USB-B port from one end (the A end) to your in-wall cell phone charger, and the other end to the mini port on your GPS. If it powers up, then its the cigarette adapter. If not, it is likely your battery.
For Reference:
画像
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
It was plugged in to the lighter outlet. Like I said it powered on and quit after about 30 seconds and would not come back on, I don't know what else to tell you but it was definitely plugged in to power.
さんによる
I know they need to be plugged into the lighter, I am NOT that stupid.
さんによる
I bought a new one and it works plugged into the same lighter
さんによる
I never said you were stupid, and you never mentioned it being plugged into the power, so I wanted to make sure all bases were covered. I also said try another power supply (the wall charger).
Now what did you buy a new one of? A GPS or a power supply?
さんによる
They need to be fully charged before use, was it bought second hand or new?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
partsman193509 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 350
