Nand chip info need
how to get Nand SN and other infos like country code, wifi Mac address if the iphone has problem in Nand if i don't have original box and even the original case
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The only way to get that info is to de-solder the NAND and read it with a NAND programmer such as the Naviplus Pro 3000. If you want to replace/upgrade the NAND, you could then write the metadata to the replacement NAND.
However, doing this destroys the user data on the NAND.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 125
