Won't power on and charger light goes out when plugged in
This is a T6 Swagtron hover board.
It just stopped working while in use. I thought it was a loose wire, since it happened after someone hit something and fell off.
The battery was fully charged before it happened. Now, it won't power on at all. When it is plugged into the charger, the green light on the charger goes off. If I plug in the charger without plugging in the board, the green light on the charger is on. Then when I plug it into the board, I hear a pop sound and the charger light goes off. I'm thinking it is some type of short. Do you think it needs a new circuit board? Is there a way to test?
5 件のコメント
Jeff Johnson, did you ever find out what was wrong?
Sarah Burnell さんによる
I also have this same problem ..help
Fatboy15 Thomas さんによる
Same here faint poping noise when pluging in to plugged in charger, the thing was brand new less then a mile when it stopped working
Karl Matson さんによる
@karlmatson does the light on the charger aswell on yours
daniel さんによる
Yes the light goes out on the charger when I plug the charger cord into the hoverboard
Karl Matson さんによる
