メインコンテンツにスキップ
Laptop will not charge in cart, but will charge with external adapter.
We have a Dell cart that holds 30 Dell Latitude 3340's. Specific laptops have started to not charge while docked in cart. They will charge with external AC adapters. The path is the following: Power goes to cart, AC adapters are plugged into outlet behind laptop, AC adapter plugs into a female-to-male adapter that is mounted to a try, laptop slides into tray to charge. I have tried changing the battery, changing AC adapter, changing tray. Nothing seems to get the laptop to charge via the dock. Other laptops charge in the same tray.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
After further troubleshooting, I have found the issue. Removed bottom cover of laptop to expose DC jack. Found the jack was slightly shifted inward. This caused the slot adapter to not make a full connection. Pushed jack outward and secured bottom plate. Laptop now charges in tray.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Aaron さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 122
