Screen Repair - LCD Plugs into Logic Board
I am trying to plug in the final plug into the Logic Board and am having trouble. It will click and then unplug itself nearly instantly. Help?
assuming you got a high grade part. (oem standards are the best you can get) Then the issue may be with the connector on the board. also, you will need to hold the screen vertical for the best effect of installation. dont try to connect the screen while its laying down.
You may have also gotten a screen with a defective Connector, in which case, your suppliers warranty should cover it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 55
Sounds like one or both sides of the connector have been damaged. Take a look with a magnifying glass.
Steve さんによる
