having issues with my toyota avalon
I'm seeing vsc on my dash what does that mean
この質問は役に立ちましたか?
この質問は役に立ちましたか?
madazu2002 VSC = vehicle stability control. The light warns that there is a problem somewhere in the vehicle stability control system or the traction control system. You'll see this come on with the check engine light as well as traction control light. I suggest you get the OBD codes checked to see if there are any codes that could indicate that there is an issue with this.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 54
