No audio when I'm radio mode
Single din PYLE. PLDAND72 HAS NO AUDIO WHEN SELECTING radio but all other modes it has audio
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @ezedzel
1. Has the radio function worked OK before?
a) If not, have you selected the correct radio area setting for your location?
(click on image to enlarge for better viewing)
2. Can you tune into radio stations at all, AM and FM?
a) If not have you checked the antenna connection on the back of the unit?
(this is for a Pyle PLTDAND72 - is this the correct one? Click on image to enlarge for better viewing)
b). If you have, are you getting static when selecting "tuned"radio stations especially AM stations?
If you have selected the correct radio area location, verified that the antenna is connected correctly and still cannot get any audio out when in radio mode try selecting the Default option in the radio settings area to see if this resolves the problem.
If it doesn't help either then perhaps the radio function is faulty. How old is the unit? It may still be covered by the manufacturer's warranty.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 128
