メインコンテンツにスキップ
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
79回答 すべてを表示
Why does my washer stop at every cycle? How do I clean the debris trap
1. The washer stops a lot. it Stops before the rinse and we have to manually change it to rinse. The same as spin. We have to manually change it to spin for it to spin..
2. Also. There’s pet hair in the washer. Where is the debris trap?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer may stop mid-cycle. To determine if the lid switch assembly is defective, use a multimeter to test each of the lid switches for continuity. If a lid switch does not have continuity, replace it.
Cause 2
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the washer door is not latched shut, the door switch prevents the washer from operating. If the door lock is defective, the washer may stop mid cycle. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, consult your washer’s diagram and use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
Cause 3
Water Inlet Valve
During the rinse cycle, the water inlet valve opens to allow water to enter the wash tub. If the water inlet valve fails, the washer will continue waiting for the water to enter the washer, causing it to stop mid-cycle. To determine if the water inlet valve is defective, use a multimeter to test it for continuity. If the water inlet valve does not have continuity, replace it.
To clean the lint trap:
Step 1
Lift up the lid to your Kenmore washing machine.
Step 2
Twist off the top of the agitator, the bar in the center of the machine that moves the laundry around.
Step 3
Pull out the plastic lint trap. Empty any debris in the trap and throw the debris away. Place the lint trap back into the agitator.
Step 4
Screw the agitator's top back on.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you. After looking everywhere for it I finally pulled the top of the agitator off and found it. but trying to figure out how to take the trap out now.
I’ll chevk everything else.
さんによる
コメントを追加
回答を追加する
Tiara さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 1,940
