メインコンテンツにスキップ
様々なテレビブランドとスタイルの修理ガイドならびにサポート
9048回答 すべてを表示
shut off and won’t turn back on
I was watching my Toshiba tv yesterday and out of nowhere it just shut off and won’t turn back on... I’ve tried different outlets, unplugging everything and holding the power button for 20 seconds and nothing is working... any suggestions for me?? Thank you!!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
@ali_more14 what model is your TV? Do you have a multimeter or can you get one as well as some basic tools?
さんによる
It’s 55L31OU. Yes I do and have lots of tools just no idea where to start
さんによる
コメントを追加
1 件の回答
Are any of the tvs leds showing any life such as a standby light? I would also look extremely close and see if you can see a picture in good lighting, I had a Toshiba that had a backlight issue so might be worth checking.
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
Nope there’s no lights whatsoever
さんによる
You say you've tried different outlets have you tried a different power cable?
さんによる
Yes I have... I wonder would it sound as if the actual cord from the tv to the outlets has blown? It’s odd out of nowhere that would happen?
さんによる
I’ve got it plugged into a power bar and everything else plugged into it is working
さんによる
Its not common but it is possible its just worth it to check every issue outside the tv before we look into taking the back of and looking at the tv its self. the fact there isn't even power light on the tv indicates a power supply issue I would be sure that you know there is power getting to the tv. If your certain power is getting to the device then your problem is with the PSU board. its common for them to have fuses on you could start by checking them.
さんによる
3件以上のコメントを表示
コメントを追加
回答を追加する
Allison さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 549
