メインコンテンツにスキップ
The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
114回答 すべてを表示
Driving Across Country, Should I be Worried?
I have driven this vehicle from CT to TX and back, I am about to do it again. I
am not the original owner, I am the third owner and I have had it since 2015.
I keep up with all oil changes and have had the brakes done, new tires and
all belts and fluids checked ( radiator hose was replaced) No serious
problems with the car as far as I can tell. The electrical system has been
crazy since I got the car I have been able to hear a hum, and sometimes the
fan comes on when I am idling even though the car display and feel the
hood reveal the car is not overheating. What if anything should I be worried
about breaking down? It will mostly all be highway driving.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
MaryAnn Martinez anything is possible but not very probable. Continue with proper maintenance and proper tune-up and "keep on truckin'"! No much sense in worrying about it until you actually have an incident.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The fan coming on is all part of the normal operation of your vehicle. When the thermostat opens, allowing coolant into the engine, the hot coolant is returned to the radiator. The temperature sensors tell the fan to turn on to cool off the hot liquid. When driving at highway speeds, the fan may not come on at all. The air being forced through radiator is usually enough to keep the engine running at normal operating temperature.
From what you described, you shouldn't have any worries about your trip.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
MaryAnn Martinez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 48
