メインコンテンツにスキップ
2017年Appleは13インチMacBook Airに新Broadwell Intl Core i5プロセッサを搭載して登場させました。バッテリー寿命の改善とパフォーマンスがわずかに向上しました。
353回答 すべてを表示
No video capture devices were found in System Information
Hi,
The built-in camera of my MacBook Air 2017 stopped working.
I was able to use the camera of my laptop with Skype or FaceTime. It was working very well.
I went to About This Mac > System Report > Camera: No video capture devices were found.
I tried to solve the issue using Terminal > sudo killall VDCAssistant. It didn't work.
Please help!
Thank you
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
選択されたソリューション
First you system is likely still under warranty (one year for defective parts) so I would first visit an Apple Store to have them take a look.
If that don't pan out then you could try reseating the camera cable on the logic board to see if that fixes it (I strongly recommend you do this after visiting Apple). Here, the IFIXIT guide you'll need to follow: MacBook Air 13インチ Early 2015 ロジックボードの交換 Follow the first three steps, then jump down to Step 22. Carefully remove it and then put it back in, reconnect the battery is it working now? If not you'll need a new display assembly as the camera is mounted within it and not easy to get to.
このアンサーは役に立ちましたか?
スコア 1
コメント:
Hey so I only need to the step 23 or from 23 to the end? And seem like disconnecting the camera is from step 22?
さんによる
@Lê Nghĩa - Sorry the guide was altered so the step numbers changed you only need to do step 22 after first disconnecting the battery.
さんによる
コメントを追加
回答を追加する
Pierre さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 30
今までの合計 4,054
