大きめのアップルMacBook Airラップトップはデュアルマイクと802.11ac Wi-Fi接続を特徴としています。
320の回答 すべて表示
Key too sensitive after plastic sheet under plunger damaged?
I noticed a few days ago that my X key was very sensitive to touch… to the point where I could type out that letter by just rubbing the key. I took the cap, scissors and plunger off that key and a few others to see what the problem was and noticed that the plastic film thing that sits directly under the plunger for this specific key had a dent in it… only difference between the other keys I looked at that could possibly cause this.
Is there a way I could fix this DIY?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Are you a heavy user of the X key?
による
コメントを追加
1回答
最も参考になった回答
Sorry to say you'll need to replace the keyboard to fix this. Most likely you had something spill into the keyboard.
The plastic keyboard backlight & light guide and the metal hinge frame & the switches which is held in by screws & rivets which does take some effort to take apart. You really can't safe the old keyboard on this model.
I'll warn you Louis is a bit foulmouthed but he goes over the process quite well. Here's his YouTube vid: Macbook Air A1369 A1466 Keyboard Repair & Replacement - how-to step by step guide
Make sure you order the new keyboard with screws as you'll need to replace the rivets with them.
この回答は役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
ESWAT さん、ありがとうございました!
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 50
