メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2687回答 すべてを表示
iPhone 6s battery smell
When I was replacing the battery of my iPhone 6s the adhesive strips broke. So as the ifixit guide suggests I tried to use dental floss along with the tools in the kit to pry it out. I thought I almost had it when I started smelling something coming from the battery, at this point I stopped immediately and placed it in the other room. What should I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
5件の回答
最も参考になった回答
Either get someone to remove the battery for you or you will have to end up prying it out.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Or just take it outside?
さんによる
コメントを追加
Hi
Sorry to ask did u disconnect battery from motherhood.
If not disconnect battery first.
Remove Lcd from phone.
Now take some plastic card like playing card and put it under battery from left side of phone and slide it slow under the battery. And don’t use any metal thing to take out battery.
In this way u can remove battery safely.
Always use safety gears.
If still not confident better to go to some repair store.
Regards
Phone beats
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Yes everything's removed and disconnected
さんによる
I am mostly concerned about the smell
さんによる
I think smell is due to when to cut outer black layer of battery.
Don’t try to take battery with any metal thing. Remove it with plastic playing card.
Again if you really not confident better to go to repair store.
Regards
さんによる
Please keep spam out of your answers. You can advertise phone beats in your profile page.
さんによる
@captainsnowball this one too:
What does it cost to replace the glass?
さんによる
1以上のコメントを表示
コメントを追加
Lol when I read the question I was like 'Wait why are you smelling the battery?' XD
Anyway, the battery might be corroded or leaking.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Honnestly had the saaaame issue and got scared quick cuz you always here about batteries exploading so when i started smelling a sweet toxic smell i just immedietly pried it out to avoid ruining the phone and it worked. Now im about to install the new battery
さんによる
Lol...At least you got it taken care of.
さんによる
Haha yeah about that, i apparently ordered a ifixit iphone 6 tool kit battery replacement.... I have an iphone 6S soooo when i was trying to install the battery to my surprise wouldnt fit, because iphone 6 and 6s are not compatible, huge blow i needed my iphone this week and now Iphone6S batteries are out of stock, if you happen to know how to help before tomorrow 15:00pm EST id be glad to order another online.
さんによる
I dont...Sorry
さんによる
コメントを追加
use a hot air in the back of the iphone (not very hot) the glue under the battery will be more elastic and you can remove it without problem
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
60°C / 140°F to be clear. 80C is okay too if it's not hot enough depending on how hot it is in your area.
さんによる
コメントを追加
Probably your battery has a small hole . But I recommend to change your battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Trey johnston さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,504
