メインコンテンツにスキップ
Appleの iPhone 5sは2013年9月10日に発表されました。このデバイスの修理は全モデルの修理と類似しています。そしてスクリュードライバー、こじ開けツールが必要です。GSM か CDMA、16か32、64GBがあり、色はシルバー、ゴールド、スプレーグレイが選べます。
3888の回答 すべて表示
iPhone 5s won't turn on
Hi! I have an iPhone 5s fallen in water. He was in bootloop so I tested the battery and it was dead. I changed the battery and the bootloop continued. So I remove the EMI shield and there aren't water damage but now the phone won't turn on. Initially it warming around the Power IC and all the capacitors around it were short-circuited. I heated up the Power IC and now the capacitors are ok but the phone won't turn on. I leaved in the battery all night long and it has fallen from 3.80V to 3.16V. Please, can you help me?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
2回答
I had a similar issue with an SE, got wet, wouldn't accept a charge, was bootlooping... new fully charged battery didn't fix it - replaced the charging port board and everything worked after that. If you don't have another 5s to swap parts with, I suggest trying a new charging port board.
この回答は役に立ちましたか?
スコア 0
コメントを追加
I fixed a iphone 6 that was water damaged by replacing the battery, and when it still wouldnt turn on, I replaced the screen and it worked like new, maybe try replacing the screen?
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eliseo Di Iorio さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 772
