メインコンテンツにスキップ
2012年6月12日に発売。Turbo Boost付きのインテルプロセッサー、モデル番号は A1278。
1209の回答 すべて表示
MacBook backlight keyboard does not work, and doesn't sleep when lid
Hi,
I have a MacBook Pro 2012 13" (Non Retina) model,
The MacBook has no backlight keyboard and the MacBook does not sleep when you shut the lid.
I feel the issues are related and it could be damage to a ribbon cable, but I'm not sure what one.
I have tried SMC and PRAM Resets.
Thank you for any help
Bradley
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Are you sure it's working?? No display, keyboard or trackpad sorta tells me its dead. Are you able to see your desktop using a flashlight through the Apple Logo?
What is the background here? Did the system get wet or dropped?
による
Hi Dan, sorry I think you misunderstood my question, the only issues are, that the MacBook does not go to sleep when you shut the lid, and the backlit keyboard does not work, apart from that the Mac works perfectly
による
Phew! Thats better!
You got to stop letting it drink Red Bull as I wouldn't sleep either ;-}
による
I have got the CD Drive working by disconnecting the ribbon and reconnecting it, I have 2 issues still, MacBook does not sleep on lid shut and backlight keyboard
による
It hasn't had water damage haha
による
表示する 1 他のコメントを
コメントを追加
iPhoneのバッテリーキット
Only $29.99
Buy Now
iPhoneのバッテリーキット
Only $29.99
Buy Now
1回答
選択されたソリューション
You'll need a magnet and a paperclip (Steel). Using the paper clip you should find on the upper edge of the lid where the magnet is. I believe the 13" has two like the 15" (its been awhile). If you fold the display down you'll be able to locate the sensors location on the uppercase, using a magnet to set it off.
Are you able to put the system to sleep then?
As for the keyboard backlight you'll need to check the ribbon cable connection. Refer to this IFIXIT guide: " Unibody Mid 2012のロジックボードの交換] jump down to Step12 & 13.
If you can't get the system to sleep testing the sensor then you may have a similar problem with the ribbon cable jump to Step14 to check it out.
この回答は役に立ちましたか?
スコア 0
コメント:
Thank you for the detailed reply Dan, I have just checked the ribbon for the backlight keyboard and it appears the connector / latch has actually came off the PCB, not repairable by me !
As for the display not sleeping when the MacBook lid is shut, I can feel the magnets in the display, there is two near the isight camera, holding the magnet near these does not make the Mac sleep.
I have another MacBook (Same generation)... and on that one I can make it sleep by rubbing the magnet to the left hand side of the keyboard, however on the one im trying to fix this does not cause it to sleep.... could this stand out as anything ?
Thanks again
による
I told you to stop feeding it Red Bull ;-}
Sadly the sensor is gone. Follow this guide: MacBook Pro 13" Unibody Mid 2012のバッテリーの交換 as you need to get to the battery tester on the side where the battery is blocking access to it. Here's the needed part: Sleep Sensor/Battery Indicator Light - Apple P/N 922-9523
による
Haha ;)
Thank you Dan, I really appreciate you taking the time to help me
による
コメントを追加
回答を追加する
Bradley Cousins さん、ありがとうございました!
統計データを表示:
過去 24時間: 4
過去 7 日: 16
過去 30 日: 49
今までの合計 1,695
