メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1623回答 すべてを表示
Display showing whiteout (or colored fuzz) then shutting down
My macbook pro started having this problem about 4 months ago. When I'm working on it, the entire screen suddenly displays colored fuzz (like the black and white fuzz on an old tv screen when there's no signal, except it's also colored). Then after about 30 seconds of doing this the screen goes black and the computer shuts down.
I've tried connecting it to an external monitor by HDMI but the external monitor shows no signal when the laptop does this. I took it to an apple store about 4 months ago (when the problem started) and they said it could be something with the graphics card. They wanted to charge me $400 to replace it. Unfortunately I wasn't in a position to do that.
Another thing, I use my computer for movie editing and am in the middle of a huge project. So the laptop has been getting a lot of graphics work.
Last thing, I have traveled lots with this computer including the dusty outback in Australia. Could this problem be because of dust on the logic board? Or has anyone else had this problem?
I really appreciate anyone's help.
Hunter
Update (02/03/2018)
Ok, so so far it seems to be running okay. It still seems a little slower than usual but it hasn't shut off.
Here's what I did: As per Dan's suggestion I removed the logic board and cleaned all the dust off of the board. I didn't reapply thermal paste.
There were clumps of fuzz clogging up the vents to the fan and the top side of the logic board was covered in dust. After taking it apart I used some canned air to blow it off and then some q-tips with isopropyl to clean it further. Then I reassembled everything. Here's some pictures of the parts with dust and then after cleaning:
I'm using the laptop right now to do this post and I have final cut pro running in the background and so far it hasn't shut off. I'm hoping and praying this worked!
If I continue having problems I'll let you know.
Thank you all for your suggestions!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
One of these is your system: MacBookPro9,2 as you can see they only have the intergraded Intel HD Graphics 4000
さんによる
コメントを追加
2件の回答
ベストアンサー
Wow! You are having some fun! I took the train to Alice Springs from Melbourne and on to Uluru Kata (Ayers Rock) by bus. Boy it gets hot and dusty!
Given the season - Summer for you. You'll need to watch the static electricity! As its very dry in the outback. Work in a small room with a humidifier and use proper ESD protection protocol so you don't kill your system.
I would first do a good dust out of your system. Hopefully you can get a soft paint brush and a can of can'ed air and the needed tools to open your system. Follow this guide: " Unibody Mid 2012のロジックボードの交換 as I'm suspecting you'll also need to refresh the thermal past as well. Carefully bush the surfaces of the fan blades and heat sink fins and a few soft short blasts of air should push away the loose dust and debris. You'll also want to do the logic board as well. For the CPU you'll need to get some fresh thermal paste and some cleaner to remove the traces of the old paste. I would recommend getting [リンクされた製品が存在しない、もしくは無効: IF179-010] and Arctic Silver ArctiClean
The reason you need to do the paste here is I'm suspecting you're cooking your system! Video editing on a 13" system is hard on it! It does not have the best GPU services unlike the newer 15" or desktop systems for large video editing projects.
If you can you might consider renting or borrowing an iMac if you can as you'll find it's a lot better!
Arctic Silver ArctiCleanの画像
製品
$9.99
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Dan,
thank you very much for the quick response and I apologize for not replying right away. Because of this issue I have had limited computer access.
Yes, Australia is beautiful! Unfortunately I never made it out to Alice springs but I've heard awesome things about it.
So I disassembled my laptop and removed the logic board. It was VERY dusty. It also had clumps of fuzz blocking up the vent by the fan. I cleaned all the dust and fuzz on both sides of the board. I did not reapply thermal paste as I haven't had the chance to buy some, but if it continues having problems I will do so.
さんによる
@hunterjames - I wish you luck on your video. Post a link here once you get it done. Love to see the beautiful country again.
You might want to get this app: TG Pro it will help you monitor the temps and can also speed up the fan when it needs a bit more cooling (turbo mode). For $18 US its well worth it!
さんによる
コメントを追加
最も参考になった回答
This machine is a keeper. it was produced
Introduction Date: June 11, 2012 Discontinued Date: October 27, 2016
It is upgradable and repairable compared to the Retina machines.
If you find it is the GPU call Apple up and request a "Flat Rate Depot Repair".
Total cost for this in Texas is $357 shipping and tax included. They will repair any and all problems for this fee. Total time is four days and they overnight you a FedEx box.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
For sure a keeper!
But this model uses the graphics within the CPU. No dedicated Radeon GPU. It likely under powered for the task at hand. Video editing is hard on CPU & GPU.
さんによる
コメントを追加
回答を追加する
Hunter さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 777
