メインコンテンツにスキップ
Galaxy S7 Edgeは Samsungの2016年最新モデルGalaxy S7のスクリーンがカーブしたデザインです。2016年2月に発表、同年3月11日に発売されました。モデル番号はSM-G935です。
20回答 すべてを表示
Broken screen can't deactivate
I recently cracked the edge of my screen causing a few problems so I turned off screen lock and seems ok 90% of the time. Today's problem is I put battery saver on as was out and only had 5% and now I can't disable it as the screen times out straight away. To be able to get the phone screen back to working order I need to disable the saver back to normal. Help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
It fixed my problem as weel. I was unable to turn off the device and boot into recovery mode. Thanks for the post
さんによる
Hi my s7 edge has a broken screen cant see anything, and i accidentally turned on battery optimization pl3ase helo!?!?
さんによる
コメントを追加
4件の回答
ベストアンサー
Try this:-
You can force Galaxy S7 or S7 edge to power off without unlocking the phone by following these steps:
Step 1: Connect Galaxy S7 and S7 edge to wall charger with the USB cable and make sure it is charging.
Step 2: Press and hold Volume down button and Power button (holding two buttons) for about 7 seconds.
Step 3: Release power button, then volume down button.
Now, Galaxy S7 or S7 edge should be powered off. You can wake up the screen to verify. It should show a charging battery icon.
このアンサーは役に立ちましたか?
スコア 22
11 件のコメント:
I have spent hours trying to find a solution. This is the only one that works. Thank you very, very much. Now I can boot into TWRP and get all my files out.
さんによる
yes this is hard to find knowledge! On my broken note 5, this solution works too (just pressing down + power button only reboots phone, not power off). Samsung should have made it easier to force power off phone with sealed in battery
さんによる
100% working for my broken screen,Thanks
さんによる
This doesn't work for me. It's just causing the hard reset but the phone immediately powers back up. I need the phone to stay off so I can take out my sim card
さんによる
when i try this it just restarts my phone? HELP PLEASE.
さんによる
6件以上のコメントを表示
コメントを追加
My Galaxy 7 started repeatedly rebooting and the hard shut off did not work. I have a replacement phone but have files I need to get off the G7. Is there another way to cancel the automatic rebooting process that the phone is stuck in?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It's really too bad that no one has a universal fix for this. What i ended up doing was taking the phone apart and removing the battery. What could be the problem is the button mechanisms are faulty from the damage as well.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thank you very much ... It did work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 21
今までの合計 66,802
