メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2610回答 すべてを表示
Sound freezes but video continues.
My samsung isn't a curved tv but a 55 4K 3-d flat screen. After being on for several minutes the sound will freeze making a weird sound. The video continues without any problems. The tv will turn off and back on only to for the sound to freeze back up and turn back off. Please help
Update (01/31/2018)
The model # is UN55HU8550F
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I replaced the mother board (power board) and the problem existed.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
@dodge2007 et us know hat moel your TV is exactly. You will need to try all different input sources and see if that sounds issue still exist. If it does, it is absolutely possible that you are having issues with your main board audio processing IC. Post some images of your boards with your question. Tat way we can see what you see. Use this guide iFixitでの質問に画像を追加する方法 for that.
Update (01/31/2018)
@dodge2007 since you already replaced the power supply you need to check your main board. That is the one where all your inputs etc. connect to and where the audio IC is located
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
David bennett さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 442
