メインコンテンツにスキップ
2019年3月に発売。Mac Pro (Early 2009)は、IntelのNehalemアーキテクチャをAppleのプロフェッショナルデスクトップラインに搭載し、2010と2012のCPUアップデートを加えて、インテリアが再設計されたモデルです。
201回答 すべてを表示
2009 updating to High Sierra
Hello, I'm considering upgrade of my 4,1 Mac Pro (upgraded and flashed to 5.1) but I'm not sure if my GTX 970 will be still working after upgrade. That is the only reason I didn't upgraded it yet.
I don't have an original GPU. What do you recommend doing in that situation?
Thanks in advance for any help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Have you flashed it yet, if so why method did you use?
さんによる
be carefull of MAX 300W on ALL PCIe slots
さんによる
コメントを追加
2件の回答
最も参考になった回答
Hello Maciek,
I have the same Mac Pro, only with a GTX 1060. From what i saw, there are macOS Cuda drivers for macOS 10.13.x ( http://www.nvidia.com/object/macosx-cuda... ) and the drivers for the Quadro and Geforce GPU's ( http://www.nvidia.com/download/driverRes... ). So practically, yes you can install the new macOS High Sierra. The only problem is that when you upgrade it, I don't think that the GPU is going to work until you install the drivers, so it's "safer" for you to do it with a stock GPU. It might work, but I'm not totally sure, because I never tried to do it.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Have you actually done this upgrade on your machine?
さんによる
No, I have not.
さんによる
Just an update. I have done the upgrade from Sierra to High Sierra and it work good. The only problem is that you need the old GPU to be able to fully update it, because you need to install the new drivers and to go through the initial setup after the upgrade.
さんによる
コメントを追加
Hi. You can pick up the default nvidia Gfx GT120 on ebay for super cheap these days. I keep one handy just in case I need to get to the pre-boot screen. There are better cards that support pre-boot and even Metal, but this one is super handy for slapping in when I just need video to boot because of some other issue. Even Mojave will boot with this graphics card provided you installed it with a metal supported one at the time.
Not a full answer but a tip for sure.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maciek Welk さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,758
