iPhone 6s 128GB NAND
I am wondring if ifixit can provide this part: Iphone 6s, 6s plus, 7, 7plus 128GB (or higher) nand flash memory chip.
If not. Where do i find them?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Probably from AliExpress / Alibaba.
Note that you will need to reprogram the nand with a naviplus pro 300 so that it matches the wifi / by ic Mac address and be able to boot.
I assume you have the tools to remove the old nand flash chip and put the new one on.
このアンサーは役に立ちましたか?
I was told i only need the PCIE chip programmer with the memory to complete the memory expansion.
I have only found on EBAY, but, I am not very confident they will be what the listings say they will be. Also Digikey.com , but again, Digikey will only sell bulk NAND chips. So you would have to resell the rest. Hope that helps!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 5,124
