Why does a code is showing and I can not record videos?
When I turn on my camera it displays a code "E:62:10" and I can not record videos.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Error E: 62: 10 = Error initializing the lens, the image stabilizer block.
Apparently this is a problem with a lot of Sony cameras.
The lens focusing sensor has a problem because of the lens focusing gears are not working properly .
People have successfully tried give the camera (when it is turned off) a couple a sharp taps with the hand on the battery side of the case and this seems to have resolved it.
Otherwise you could take it to a reputable, professional camera repair service (experienced in Sony repairs) and ask for a quote to repair the camera.
このアンサーは役に立ちましたか?
Hi, This is indeed a very well known problem with a lot of Sony camera's. Read http://sony-e-62-10.atspace.cc/. A temporary solution could be available at https://www.youtube.com/watch?v=S53D3EfD.... Hope this helps.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 896
