メインコンテンツにスキップ
2014年6月に発売されたSamsung Galaxy S5 Activeのモデル番号はSM- G870Aです。このデバイスの修理は大規模に渡り、ヒートガンとスマートフォン専用のツールキットが必要です。
75回答 すべてを表示
How I can repair or change the audio port?
Hello,
Probably my problem is very rare, but I will ask.
So I have bought a second hand Samsung Galaxy S5 Active. Everything is working fine, except the audio port.
It shows always that earphones are connected, no matter that actually there aren't any earphones connected. Probably the phone was under water.
What I have tried:
1. to clean the audio port wih isopropyl alcohol. The the problem remains.
2. to bend very little the metal contacts in the audio port, so they won't make a contact anymore. The problem remains.
Because of my fails for repair, I want to ask if somebody have already disassembled the audio port, so I can see how exactly it works.
Or if someone knows, where I can find a replacement part.
Thank you in advance.
Kind regards.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi,
Is this what you are looking for?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Hi,
Thank you for the reply. This will be my last option.
I want to try to repair it without the need to open the whole phone. Opening the phone would be very difficult. :)
The problem is probably a very tinny metal plate which is bent, but I have no idea how were the initial positions of the plates in the audio port. Because of this I'm looking for something more likely as scheme of the port (how it works)? :/
I hope, that you understand what I mean. :)
Although thabk you for the link.
さんによる
コメントを追加
回答を追加する
Bobi さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 64
