メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2688回答 すべてを表示
Why is my iPhone 6s screen not responding?
HI, my friend accidently dropped her iphone 6s into the toilet bowl. She immediately tried putting it in rice to let the water drain out. After that, the phone turned on but the phone did not respond to touch. The screen looks fine and the home button and power button are working but when i touch the screen, there is no response. So, i was wondering is there a problem in the digitizer or logic board or anything else? Is there any way i can check what is wrong or would an lcd replacement help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
The water probably damaged the digitizer. I would disassemble it (if you're tech inclined) and dry it out that way. Unfortunately rice doesn't do much to actually pull water out, or prevent corrosion from forming. If the device is turning on though, that's a good sign. You might just need a screen replacement (new Glass/LCD/Digitizer). I've had that fix very similar problems.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
water damage is not fun. you may need to fully disassemble the phone based on how damaged it is.
iPhone 6sの分解
Electronics Water Damage
Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Reenashini Rajendran さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 56
