メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Constant white screen but able to login
Hi all,
My MacBook is displaying nothing but a white screen. I somehow was able to login to the computer. I know this because I was able to play music using the multimedia keys. I've tried resetting nvram, smc, command + r and followed all other guides which tackle the white screen problem. But none of the guides have helped me fix my issue. I can see black smudges on my screen sometimes. I booted with command + r, and I could see a greyish window (looked like a rectangular black smudge). I'm guessing that was the window which shows recovery options (reinstall etc). So I can confirm that my hard disk is booting up fine. What might be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Teja,
Do you have an external display you could try to test with? I would hook your MBP up to an external display and boot it up, if you see your computer working normally then you may have a bad display. If you get the same results on the external display then it could be your graphics card, which is unfortunately soldered to your logic board.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
I was planning on doing this. Will do it later and then let you know.
さんによる
Just connected my MacBook to an external display, and everything seems to be working fine on the external display. The black smudgy rectangular window that I was talking isn't actually a window. Don't know what it is. Should I replace the display?
さんによる
How much would it cost?
さんによる
Hey Teja,
The price varies on what condition you buy.
https://beetstech.com/product/display-as...
MacBook Pro 13" Retina (Early 2015) Display Assembly
If the external monitor works fine, I would test it for an extended period of time before making the purchase, a couple hours or overnight just to make sure it still is fine on the external. Lastly I would try to do the SMC and PRAM reset a couple more times, if still nothing works you should replace the display!
さんによる
コメントを追加
回答を追加する
Teja Reddy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 160
