メインコンテンツにスキップ
Apple Watch Series 2は2016年9月7日に発表され、同年9月16日に発売されました。
128回答 すべてを表示
Digital Crown no longer works
My Apple Watch 2 started to act funny, it would launch siri and scroll between apps all by itself.
It was acting as if the digital crown was being pressed in and rotated.
I tried the usual cleaning methods as per the apple website but without any luck.
It does rotate freely and doesn't feel sticky at all, and although it does these things it is completely unresponsive.
I have to use the the side button to navigate my way round the watch the best I can.
Does anyone have any Ideas?
Many Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
11 件のコメント
I am facing same problem i just want to know is this not because of update i having series one and watch were upgrde 5.2.1
さんによる
I contacted apple about this and they said I needed to clean the Digital Crown in warm water. When in the water turn and press de crown a few times.
さんによる
is here a place to buy anything that includes these in a part? my 2nd gen is doing the same thing, however mine only started after version 5 was released.
さんによる
Same here, afther last update looks like the watch is living its own life. Activating siri out off the blue and unresponsive when pushing the crown..
さんによる
Time to visit an Apple Store to get your watch repaired.
さんによる
6件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
The digital crown uses a set of detectors that note the rotation. It sounds like the detectors have failed. You can see them here in the Teardown: Apple Watch Series 2の分解 in Step13.
Given how far you need to get I would just let Apple deal with it. They at least have a flat fee for the repairs.
このアンサーは役に立ちましたか?
スコア 1
7 件のコメント:
Thanks for the reply, I am out of warranty (by one month) and its seems like a high price, I'd rather spend a bit extra and get the series 3
さんによる
Its still cheaper ;-} Apple Watch Pricing
さんによる
I went to Apple for the same problem and they wanted to charge me $229 to fix it. The new models are $249.
さんによる
@scooba4 - Agreed! Its on the high side given the cost of a new watch (cheapest model). Its when you get to the stainless steel or Ceramic cases it becomes less of a bite.
さんによる
@danj you think there might be a "Flat Rate Repair" price direct from Apple?
さんによる
2件以上のコメントを表示
コメントを追加
回答を追加する
casey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 24
今までの合計 16,378
