Why wont my phone turn on
ive recently purchased a new screen. when put the screen on and put my phone on the charger it was on a boot loop. them when i took it off the charger it didn't turn on.
There are a couple things this could mean. It sounds like it was bootlooping .
1) Check the battery connection to the motherboard. Usually bootlooping can be linked to the battery.
2) The screen can be defective. Depending on where you got it, it could be common. I suggest Mobile Defenders for a screen.
3) Something could have happened during the repair that could have caused motherboard damage. This usually happens when screws are put in wrong holes, no anti-static wristband was being worn, or the battery wasnt unplugged during repair.
Hope this all helps :) Good luck diagnosing the problem.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 41
Can you tell us more about it? Was it dropped? Did it get water inside?
Jennifer Beth Barton さんによる
